How to change the Print Output file path !!
RitchieParis
RitchieParis
Fusion dont recognize my printers (Canon, HP) in the "Printer" menu so that I must to print in pdf first and then use prewiew or Adobe for print !!!!!!
The output file have a default path,  I must change it each I print, it's very restrictive, is there a possibility to change this path somewhere ?
I didn't see this possibility in the preferences (except error from me)
jorge_garcia
Hi @RitchieParis ,
I hope you're doing well. Are these printers connected directly to the computer or are they network printers? Let me know since that might give us a clue.
Could you try this on Windows? That will also help us narrow down if it's an OS discrepancy also.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
RitchieParis
Hi Jorge,
Thanks for your reply, I tested in USB and Ethernet mode and same problem, sorry I don't have any Windows at my office and home !
But it works perfectly with Eagle 9.
Best
jorge_garcia
Hi @RitchieParis ,
Dang, OK. I'll see if I can think of something else. In the meantime you can change the path by just clicking on the 3 dots to the right of the path.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
RitchieParis
Hi Jorge,
Thanks my friend sure but I have to change each time I want to Print !! not really Convenient😩
Best
