Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to change the electronics schematic sheet size?
1 REPLY 1
jkardach3R2M3
222 Views, 1 Reply
I've created an electronics document, and by default it was set to a B schematic size.  I have changed the preferences to create A schematic sizes, but the existing design is still set to a B-size.  When I print, the schematic frame size is an A-size, but it splits it across two pages as it believes the actual schematic size is B.
Is there a way to change the current schematic size of an existing fusion 360 electronics design?  I would like to change it from its existing B-size to an A-size.
Any help appreciated,
Jim Kardach
thanks,
Jim Kardach
Labels (3)
1 REPLY 1
Hello @jkardach3R2M3 ,
you can change this also in the print-dialog:
Sorry, it is the german version. Should be "scale factor" and "page limit" in english.
Eagle 9.6.2 / Fusion 360
Working with Eagle since Version 3.x
Technology Administrators
