Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to change orientation of components in arange tool?
1 REPLY 1
jason_frauchigerWC7YH
249 Views, 1 Reply
I want to arrange my components around a circular structure, as can be seen in the first image. The problem is, that I want the individual components to be rotated in such a way, that the cathode connector is at the board outline (see image 2). In the arrange tool, I can't find an option that defines the rotation of the individual components. How can I do this?
1 REPLY 1
in the arrange submenu you can add 90 or 270 degrees to the "start angle" and i think you will get what you want. here i just made an example with a resistor. you see adding to the start angle can change the orientation of the components in place.
