I have a device called TESTPAD, it contains a number of various diameter holes as well as solder pads.
I have never really figured out how to remove or replace a 3D model for a part (or part variant).
But now, I need to get to the bottom of this.
Here's the device with it's variants. I have made an "invisible" 3D component for the SOLPAD_2 footprint and now want to replace the 3D models for all the other footprint variants to use the same.
But I cannot figure out how.
So, I try to use "Replace Package" which sounds like it will do exactly what I need.
But, nooooo, of course not.
This will replace BOTH footprint and package!
And I will get the dialog for mapping the pads, with the SOLPAD_2 footprint, saying "A different footprint is present in the device" OR, it will replace my footprint without further warning.
Why it sometimes does one thing and sometimes the other is a mystery.
Anyway, it is NOT possible to "Replace Package" as it says.
So, HOW do I do it?
It HAS to be possible to reuse the same package for several footprints, for instance all SOT23 or so.
Or, as I just need now, packages without a 3D representation.
Edit:
It seems the problem is because of the use of the term "Package" to refer to both footprint (PCB) AND package (3D model), in some places.
For instance, trying the above in a different way, I try to add my new solderpad I made with an "invisible" 3D package.
I use the usual "New" in the dialog and "Add Local Package" and that's where it kinda breaks.
Now, package is suddenly BOTH footprint AND 3D model (which are normally what's being referred to as "package").
The confusion is total, and of course it doesn't work.
