Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
how to change odb++ file output directory ?
1 REPLY 1
franck.malepart
175 Views, 1 Reply
Hi
I have a problem to create a CAM processor with a custom output directory.
I've already posted a problem about the gbrjob directory and the solution was : do not generate it
Now, you add the odb++ file generation and it have exactly the same problem but there is no option to disable it.
Why each time you do an update of the software, i have to post on this forum ? is there a way to disable auto update of the program ?
This was my previous post with the same problem:
I'm able to change every file output except the gbrjob/odb++ file. I'have changed the output directory to %PROJECTNAME/%FOLDERCONTAINER/%N/ but the gbrjob/odb++ file is always generated at the %TEAMHUBNAME/%PROJECTNAME/ location.
Where I can change the gbrjob/odb++ output directory ?
Labels (1)
1 REPLY 1
Hi Franck,
Firstly thanks for using the ODB++ feature.
Unfortunately in this 1st iteration of ODB++ output there is no way to not add the %TEAMHUBNAME/%PROJECTNAME/ to the output directory. I have already fixed this issue and a fix will be available in the next Fusion360 minor update. There will be a new option to not add the TeamHub directory to the ODB++ output file path. Hopefully this will help you.
Please let me know if you have any other questions and I will try to help.
Kind Regards,
Constantin Popescu
Constantin Popescu
Principal Software Engineer
