02:54 AM
I have a problem to create a CAM processor with a custom output directory.
I'm able to change every file output except the gbrjob file. I'have changed the output directory to %PROJECTNAME/%FOLDERCONTAINER/%N/ but the gbrjob file is always generated at the %TEAMHUBNAME/%PROJECTNAME/ location.
Where I can change the gbrjob output directory ?
Link copied
