Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to allow overlap on placement
2 REPLIES 2
eliott_trotebas
84 Views, 2 Replies
I want to place two components at the same position  but the router don't allow that cause of the pad overlapping.
How to disable DRC live verification/blocking ?
I set all DRC rules to "0", still the same problem, I can't place where I want.
DRC setting said with 0 the rule is disabled but seem not working.
Eliott.
2 REPLIES 2
Hello @eliott_trotebas,
I hope you're doing well. Go near the bottom of the screen you'll find a toolbar, on the far right of that bar you'll see the violator modes. Set it to Ignore violators. That will allow you to place the component wherever you want.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Thank you for you fast answer.
That exactly what I was looking for.
Have a good day.
Eliott Trotebas.
