Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to add Arial Bold Font into Fusion 360 Electronics
5 REPLIES 5
ronovar
204 Views, 5 Replies
Hi, here i im attaching Arial Bold Font that i need to add to Fusion 360 Electronics, so that i can select it in Schematic Editor, i open Arial Bold Font, click Install, restart PC, run Fusion 360 Electronics and in Schematic Editor there is no font called Arial Bold, so if i can get help from Autodesk support how can i fix this?
Also one important feature that needs to be added is when user select font in Schematic or PCB Editor is missing BOLD, ITALIC and UNDERLINE buttons, so for example i have Arial and if we have button B then fond will be bold.
Thanks, and keep up very good work of importing EAGLE into FUSION 360, so that it will be one product. It has major bugs and is slow, but in next year or so it will be improved speed and bugs fixed, also another question is when ngspice simulator in FUSION 360 Electronic will have more options? For example Oscilloscope, like clicking on wires and see live changing waveforms on screen, or THD Harmonic Distrosion that is essential for amplifier design?
5 REPLIES 5
jorge_garcia2
in reply to: ronovar
Hi @ronovar ,
I hope you're doing well. To use a font other than the 3 that come with Fusion electronics, select the font to be CUSTOM then you'll be able to choose any font you have installed on your computer. The bold type is actually it's own type of font. Even though it would be nice to easily access the Bold or Italic subfonts using specific buttons, you can still get it through the combo box.
Try it out and let me know if you run into any problems.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
ronovar
in reply to: jorge_garcia2
Thank you for replay.
I have the following font selections and could not find Arial Bold, installed font that i attach in first post...
jorge_garcia2
Hi @ronovar ,
I hope you're doing well. Something here seems off, looking at the image you have Arial Rounded MT Bold which is the font you posted in the first post so I'm not sure what is missing.
Fusion 360 can use any TrueType fonts on your system. Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
ronovar
Thanks, i see that font have different name...but is working.
One big missing GUI function under settings is dark mode GUI, now is white background toolbar and sidebar and this is hurting eyes when you work about 1 hour on hobby project...so dark mode will be eyes saving.
Do development team of autodesk plan to add soom dark mode GUI into Fusion 360?
jorge_garcia2
Hi @ronovar ,
This is an overall Fusion 360 feature request. There's been talk about it since it has been requested but I don't think there are any immediate plans to implement. I'll pass this thread to one of my colleagues in case they have more info.
Best Regards,
Jorge Garcia
