Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How do I add a global variable to my schematic?
3 REPLIES 3
infinite.machinery
507 Views, 3 Replies
As the topic says. I want to add a global variables named DRAWING_NAME. How is that done?
3 REPLIES 3
Hi @infinite.machinery,
I hope you're doing well. The dialog for this functionality has not come into Fusion 360 yet. In the meantime, I'm pretty sure the command line syntax will still work.
ATTRIBUTE * nameofattribute 'valueofattribute'
The * is very important that's what makes the attribute global.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
This won't work if I try to use ATTRIBUTE * nameofattribute 'valueofattribute' in library device. It will say that invalid character in attribute name referencing * character.
In schematic sheet it won't give any error but there is no way of accessing that attribute if that was even created.
I hope you are doing well!
We support Document Attribute in Fusion 360 V2.0.13615.
Please have a try to see if it works well for you.
Panpan Fan
