Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Hotkeys set through ASSIGN command don't work?
3 REPLIES 3
usoldering
178 Views, 3 Replies
When viewing a schematic or a board file, hotkeys assigned through the ASSIGN command are not working for me. I can run the ASSIGN command, I can use the ASSIGN command dialog box to see the correct hotkey is set to the correct action, however, when I press the hotkey nothing happens.
All other (default) hotkeys work fine. It's only hotkeys set through the ASSIGN command that don't work. Can anyone else confirm this issue?
Tags (3)
3 REPLIES 3
panpan_fan
in reply to: usoldering
Hi @usoldering
I hope you are doing well!
Assign command can't work now. Our develop team is working on it.
I will let you know if we can support that.
By the way, you can also try to set shortcut for commands. Hope it can help.
Panpan Fan
usoldering
in reply to: panpan_fan
Thank you for the answer. I can understand how it would conflict with the F360 environment. As a workaround I've installed a keyboard macro software to automatically activate command line mode and type out the command. The best of luck to the F360E team.
panpan_fan
Hi @usoldering
We support the Shortcut command in Fusion 360 V2.0.13615.
You can define the shortcut for commands by yourself.
Please have a try, thanks!
Panpan Fan
