hole instability
I have a PCB with board outline file that I am attempting to add mounting holes to. I have applied NPTH holes in the 2D PCB view which when pushing to 3d version display correctly the first time. However, if I return to the 2Dview, modify a component position and push back to the 3d view multiply hole errors are listed and all is shown is a brown board outline with no components pads etc. When the holes are deleted and 3d view activated the PCB returns.
I have attempted to then successfully position the holes in the 3d view. If I then push this back to the 2d, all is good but when returning to the 3d an error again occurs reducing the board to its barren brown state, except I can't then remove the holes due to being placed within the now non functioning 3d view.
Is this normal?? What am I or the program doing wrong.
Alternative question, what is the most stable process for adding mounting holes to the PCB?
