Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Hole in footprint
4 REPLIES 4
clausenBF2XY
746 Views, 4 Replies
Hole in footprint
Hi all
How do I add a hole in the footprint? I have created a component for a pressure sensor. The port on this particular model is facing downwards (see image below). Hence it requires a hole drilled in the middle of the footprint. And I want it to move with the component, not add it as a mechanical hole later on, as this is a sure way to forget it.
I cannot find anything related to holes in the footprint or the package editor. I only see that I can add holes in 3D-view, but then it is not associated with the part. In Altium Circuit Maker, I would add a board cutout or a pad without plating. I cannot figure out both in Fusion 360.
Thanks for your advice, I am a rookie considering Fusion 360 Electronics.
4 REPLIES 4
phaggren
in reply to: clausenBF2XY
Hi!
If you want to add just a basic non-plated through hole in the footprint editor, there is a button under the "Create".
clausenBF2XY
in reply to: phaggren
Thanks, that worked! I actually saw that and also tried the command line to insert a hole, but it would never show up. I had then to save the component, go to the PCB file. delete the component and re-insert it. It did not auto-update nor did it work with the replace command. In fact, the replace command led to some kind of graphical error where the 3D model was only a flat black piece.
phaggren
Yes I have the same bug. The link between libraries and design is really flaky.
Especially the replace command what just results a black square.
Hopefully they will fix this soon.
panpan_fan
Hi @phaggren  @clausenBF2XY
Today we release Fusion 360 V2.0.10027 and now the package can show well when you change footprint and repalce the part.
Please have a try, thanks!
Panpan Fan
