Hexagonal or honeycomb pattern for components
a_kononovNW435
a_kononovNW435
Hi!
I would like to know if it is possible to place electronic components on a PCB in a honeycomb shape as suggested in the specification. I was able to place the components in either a rectangular or circular shape, but there is no way to specify a direction other than 90 degrees, as is done for example in the 3d design.
Best regards,
Anton
jorge_garcia
Hi @a_kononovNW435 ,
I hope you're doing well. If the components are hexagons this would be a circular array, you would then have to rotate the individual hexagons to get the honeycomb.
Let me know if you continue to run into problems.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
a_kononovNW435
Dear  Jorge,
thank you for your fast reply.
With circular array it is clear, but I need to put 168 LEDs.
I found solution - one could use two rectangular arrays - one is shifted to another like in this screenshot:
and I have two more requests - to implement rotation function of each component in array like it is made in EasyEDA:
I found only possibility to choose direction of array.
one more thing - ratlines and pointer to geometrical center of components have the same color and for symmetrical components like resistors, which are aligned one can not distinguish them:
It would be helpful if one could have more  settings in the palette.
Best regards,
Anton
