Help with Minimum Blind Via Ratios
I'm somewhat confused regarding what the criteria to pass a DRC check is with regards to the Min. Blind Via Ratio. Referencing several of the responses to this post from November, I was under the impression that this flag only appeared if the width of the drilled hole/the depth of the hole was greater than the MBV Ratio. My design has 5.03938mil of dialectric material between layers 1 and 2 and a minimum drill size of 11.81102mil. The ratio between those works out to 0.4267 and the listed ratio is at the default of 0.5 which, given the comment from a developer on that thread, which I will paste below, should be fine.
- The Via Depth is calculated by adding up all dielectric thicknesses between the via start and stop layers (the copper thickness is not added);
- The Blind Via Ratio is calculated as the ratio between the Via Depth calculated above and the current Via Drill size and then is compared against the Min Blind Via Ratio from design rules, like: Via Depth / Via Drill Size > Min Blind Via Ratio if this inequality is true then a DRC Blind Via Ratio Violation is created. The DRC Blind Via Ratio Violation is only reported if there is no micro via drill size violation.
I'm still quite new to PCB design and Fusion 360, so I may be misunderstanding something here. I would appreciate any insight that could be offered in this, as I'm quite confused as to what's happening.
