Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
heat spreading in cooling analysis
1 REPLY 1
eric_engineer
84 Views, 1 Reply
Is there any support for heat spreading such us a vapor chamber, or graphite spreader?  Any support for interface materials between the spreader, IC, and heatsink?
Thank you
1 REPLY 1
In Fusion Electronics cooling, the calculations support conduction and convection in solid parts/bodies and the fluid domain. The heat sink is the only idealization model that is currently available and is dedicated to the extruded fin heat sink. There are no special models dedicated to vapor chambers, graphite spreaders, and interface materials between components. However, it is possible to define a solid body with a higher thermal conductivity allowing us to simulate the mentioned things. A higher thermal conductivity would model more efficient heat spreading.
Igor Krolikowski
Software Development Manager
Product Design & Manufacturing
Autodesk, Inc.
