Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Having trouble with altium pcb import
2 REPLIES 2
salesMUBBN
153 Views, 2 Replies
In altium I export my PCB and select as single component but when I use this in my design all the components are not jouing together. I tried combine commend but it keeps wasnting a body to combine to but the import consists of a bunch of "open Cascade step translator objects".
How can I get my altium PCB into fusion 360 as a single entity please?
2 REPLIES 2
jorge_garcia2
in reply to: salesMUBBN
Hi @salesMUBBN,
I hope you're doing well. For bringing into Fusion 360 a step export from Altium would be the best option. Once the step file has been imported then you can combine it within Fusion 360.
Let me know if you continue to run into problems.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
salesMUBBN
How do you do the combine? The step imports as a bunch of element and when I try to combine, the dialog keeps wanting a a target body, but there is no body.
