Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
>pART returns same as >NAME
4 REPLIES 4
silvio3105
105 Views, 4 Replies
text variable >PART returns same as >NAME(designator).
As described in https://help.autodesk.com/view/fusion360/ENU/?guid=ECD-TEXT-VARIABLES >PART should return component name (21-0010 in my case).
4 REPLIES 4
silvio3105
in reply to: silvio3105
Bump! @jorge_garcia2
jorge_garcia2
Hi @silvio3105 ,
I hope you're doing well. >PART is actually the same as >NAME, it's not commonly used, usually limited to components like relays where on each individual symbol you want to know what component it belongs to.
If you want it to show the device name you have a couple of options.
1) Set value to OFF in the device editor. When you do this by default the value will be the device name. Main problem with this is that the value is no longer available to store 200. You can use a separate attribute to display the 200 or you can just hard code it in. Since it's your in-house part number hard coding the 200 might work.
2) You can create a different attribute to hold the in-house part number and then display that.
I would probably favor option 1.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
silvio3105
in reply to: jorge_garcia2
I stick with custom variable >PN for custom part numbers.
But, why's there >NAME, >PART and >GATE?
Seems they return same thing.
I would like to see some variable that returns nomponent's name.
Thanks.
jorge_garcia2
Hi @silvio3105 ,
I've logged this one as a feature request.
This image from the EAGLE manual makes the distinction between >PART, >GATE, >NAME clear
Best Regards,
Jorge Garcia
