Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Globally replace components on PCB
0 REPLIES 0
Message 1 of 1
paddytHH6Q6
74 Views, 0 Replies
Hi All,
Newbie to Fusion here. I have brought in a PCB IDF file that is fairly simplified (2D + Height), and would like to replace components with the proper models. I have manually replaced the larger components but for the hundred or so identical discretes, is there a way to replace each type at once?
I've seen suggestions to select the components and RMB, Save and Replace but that does not seem to be an option for the imported components that came in under "Electrical" in the screen shot below.
Anyone know if this is possible?
Patrick.
0 REPLIES 0
