Generate Pick and Place File
Trying to generate pick and place, centroid, file and not sure how? Any help would be greatly appreciated. Thanks!
PinRudolf
Check out method 1. This gives you a quick Pick and Place file of all components but does not make a difference between top and bottom side.
Method 2 uses the Cam Processor.
Select output File: Pick And Place and then Process Job. This method is specifically design for surface mountaed deviced, it does not show through hole components. It does make a difference in component side (So 2 files; one for the bottom the other for the top side.)
