Announcements
Fusion loads the wrong model when opening a project
When opening my project folder, it shows pictures of the schematic and pcb. These look correct. However when I open the board design it is not the one that is shown in the project folder!
It loads an older version than the one shown. And I can select previous versions than that, but not the up-to-date.
Anyone who knows a solution to this? It obviously has some information about the latest version since its shown when opening the project folder, but where can I find it?
I can also say that this is the only project I have... so it's not like it's hidden in a sea of projects or anything.
jorge_garcia
Hi @Anonymous,
I hope you're doing well. That's interesting, if you look in the data panel can you find the most up to date one? In other words in the Electronics Design document you see the linked files but in the data panel you should also be able to see the board and schematic individually. If you open the file from there can you get the latest one?
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Thanks for your answer Jorge!
Sadly that didn't solve it. I am going to redo it now as well, so guess a good advice to others is just to double-check that your files are saved up-to-date before closing them.
