Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Fusion Electronics doesn't allow to place hole in a certain position
2 REPLIES 2
mario.brizida
145 Views, 2 Replies
Hi;
Please look at below pcb:
I need to placethe bigger hole (that is now on top left corner) on the  corner signed by a green circle, in order to "cut" the pcb corner in a simple way when I compose the panel (avoiding milling).
The problem is that I'm not allowed by Fusion to put it there, I think because hole limit will conflict with copper, but it doesn't. Even more important, it would allow to place hole (or any other componet) where I want and simply sign conflicts, that I correct later, as old Eagle did. With this limitation will be very difficult to compose panels as I want!
Is there any option that I need to check (or uncheck) to avoid this situation? If not, you plan to correct it?
Thank you;
MB
2 REPLIES 2
panpan_fan
in reply to: mario.brizida
Hi @mario.brizida
I hope you are doing well! Would you mind change to the Ignore Violators in the navigation bar?
For this setting, you can see the video here to understand it better.
https://www.youtube.com/watch?v=W4wkUCD9HSs&list=PLmA_xUT-8UlI0k9YsKK23onh_0VV2_DP5&index=29
Hope it can help.
Panpan Fan
mario.brizida
in reply to: panpan_fan
Thanks for your reply.
It works.
Regards;
