Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Fusion 360 "allow item to be downloaded" keeps unchecking / untoggling
2 REPLIES 2
yipeee
108 Views, 2 Replies
Hi guys!
I'm on the trial version of full Fusion 360 and when I try to share my design files on MyHub, I cannot select "allow item to be downloaded". The option is selectable (unlike the free F360 version) but it keeps unchecking / untoggling immediately after I select it.  There is no message that appears when the option unchecks itself. Is this feature also unsupported in the trial, or is this a bug?
Thanks!
2 REPLIES 2
Phil.E
in reply to: yipeee
Thanks for asking. I've seen this toggle being a little "laggy". Is it possible you've clicked it more than once? (on/off)
Couple more questions:
  • Is this an electronics design or mechanical design?
  • Can you export it from the File menu > Export command?
The trial experience should be the same as production, but I'm a little unclear if this covers all possible ECAD documents. Let me know what you find regarding those two questions.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
yipeee
in reply to: Phil.E
Thanks for your quick reply Phil!  Strangely, when I went in to F360 today it all works fine and I when I toggle it, it stays toggled now.  I'm pretty sure it was untoggling itself after a second or two before (not double clicking it), but maybe it was just a freak server problem on that day.  It's a mechanical design and I can export files fine. Thanks!
