Hi @maciej_glowacki2EU2B,
I hope you're doing well. Thank you for the picture, that was key in figuring it out. You have an unusual board shape and I fully believe that it's area is less than 80cm^2. With that said the area limitation is based on a rectangular envelope where the bottom left corner is at 0 0. The top right corner is at the copper object that is the furthest away in the X and Y axes. You have some components already placed at around 4inches in the X dimension which means that the furthest any parts could be placed in the Y axis is around 3inches, so the move you are trying to perform wont work because you are trying to place it near 5inches in the Y direction.
So the key thing here is to realize that it's not measuring the outline of the Dimension layer, but using the extents of copper in the design to form a rectangular envelope and calculating the area of that do determine how far new moves are allowed to go.
I know it's a lot so if you have any questions on the above. Please let me know.
Best Regards,
โ
Jorge Garcia
โProduct Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
