Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Fusion 360 Not Showing Circuit Board
1 REPLY 1
jon.wilder
111 Views, 1 Reply
I have a design in EAGLE that I've pushed to Fusion 360. However, when viewing the board, all of the components show, but there' s no circuit board!
Has anyone seen this before?
1 REPLY 1
jorge_garcia2
in reply to: jon.wilder
Hi @jon.wilder ,
Did you actually open this in Fusion 360?  The viewer doesn't always process the 3D PCB correctly.  If it looks the same way in Fusion 360 then the thing to check is to make sure you have a perfectly closed contour on the Dimension layer. If everything is correct you'll see a color difference between the inside and the outside of the board.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
