Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Found a "bug" when editing PCB outlines. Can't select objects.
1 REPLY 1
mad.macs
145 Views, 1 Reply
I created a bunch of circles on my 3D board sketch today. When I went to edit the board and select the holes it wouldn't let me select anything. During the sketching of the holes I changed my selection filter to all but sketch geometry to clean things up. This setting carries into the board editor for some reason, so I spent 5 minutes or so figuring out what was going on. It would seem that when editing board edit mode the selection set should revert to select all.
1 REPLY 1
jorge_garcia
in reply to: mad.macs
Hello @mad.macs,
I hope you're doing well. That's interesting, as far as I know there is no interaction between the filters of the 2 editors. Is there any chance the selection filter was adjusted before pushing to 3D PCB? The Selection filter remembers it's state during a session so that could possibly explain it.
If you can provide some images of the workflow or a screen recording that could helps use diagnose this.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
