Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Footprint pad array 4 sides
3 REPLIES 3
duncanBC5DV
164 Views, 3 Replies
Is it possible to create a pad array with 4 sides
When I select either SMD or PTH pad array tools, it starts with left and right selected, top and bottom are grayed out. If I deselect left and right, I can select top or bottom, but then left and right are greyed out. Am I missing something?
3 REPLIES 3
jorge_garcia2
in reply to: duncanBC5DV
Hi @duncanBC5DV,
I hope you're doing well. It sounds like you want to use all 4 sides. Currently the array commands don't support 4 sided footprints.
I'll make a ticket for this so that this can be improved. For now if you need a 4 sided footprint you can run the current array functions twice. You are not missing anything.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
duncanBC5DV
in reply to: jorge_garcia2
Thanks for the prompt reply @jorge_garcia2
I must say I'm still a little bit concerned as to how this feature was released without supporting 4 sides, it brings the validation testing into question, perhaps you can pass that on to your colleagues.
duncanBC5DV
Any movement on this issue @jorge_garcia2 ? It's been 8 months. I tried to run the 2-sided pin array twice and got some very strange results:
