Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Flipped board indicator
8 REPLIES 8
Message 1 of 9
silvio3105
470 Views, 8 Replies
In 2D PCB workspace, flipped board indicator is missing.
Sometimes I'm not sure is PCB flipped or not.
8 REPLIES 8
Message 2 of 9
jorge_garcia
in reply to: silvio3105
Hi @silvio3105,
Thanks for the suggestion, I have made a feature request for it.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 3 of 9
pblase
in reply to: jorge_garcia
Any progress on this yet? It's still pretty confusing which side of the board I happen to be looking at.
Message 4 of 9
Thanks for the reminder!
Pieter-Jan Van de Maele
Senior Engineering Manager, Fusion Electronics
Message 5 of 9
melisa.kaner
Hi everyone,
Appreciate you all taking the time to detail this in the forum. I'd love to learn more and will reach out via DM to schedule a quick chat. I agree this experience could be better.
Best regards,
Melisa
Melisa Kaner
Product Manager - Fusion Electronics. Please DM me for Fusion Electronics feedback!
Message 6 of 9
imadak6Y6YW
in reply to: melisa.kaner
Relatedly, is there a command that can be executed to display the back view instead of toggling with "WINDOW FLIP"?
I would like to see WINDOW FLIP OFF or WINDOW FLIP ON implemented.
I want to use a shortcut key to switch layers and flip at the same time, but I can't because that function doesn't exist.
Single layer mode seems to have a similar problem.
Message 7 of 9
pblase
Any time. One other thing: when the board is flipped, the layers are still drawn in normal order, so that the top layer still appears above the bottom. This makes it hard to see the layer that I'm trying to concentrate on!
Message 8 of 9
imadak6Y6YW
in reply to: pblase
When I flip the board, the display order changes. Confirmed with 2-layer design and 4-layer design. However, keep in mind that the selected layer will always be drawn on top (although I don't really like this).
I'm using the latest 2.0.19215 x86_64. which version are you using?
Message 9 of 9
pblase
in reply to: imadak6Y6YW
Ah, that's it. I need to remember to select the opposite layer. Thanks
I'm using the latest version too.
