Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Finishing the Autorouter disconnects patches of polygon signal
3 REPLIES 3
m_eckhard
153 Views, 3 Replies
I encountered a problem where I want to use the autorouter but it partly destroys the design. This only happened today after working in the past.
It happened after I created a polygon from the board outline to create a big GND layer. Then I used the Autorouter to trace the components. It finishes and all still looks fine (1st picture). But after clicking "End Job" it removes patches of the polygon/GND layer and displays an info which now says "(only) 97.2 % finished. Polygons may have become signal disconnected".
I didn't find a solution online or in this forum so any help is greatly appreciated.
Kind regards
Labels (2)
3 REPLIES 3
jorge_garcia2
in reply to: m_eckhard
Hi @m_eckhard,
So this is the nature of the beast in this case. You're fortunate you haven't run into this before but it was something that was an eventuality. When the autorouter runs it doesn't worry about the polygons since they can be recalculated at the end. Since the autorouter is just trying to get things connected there is a good chance that it will cut the polygons up and leave islands. At the end when the routing is done the polygons get recalculated and that's when islands can form. There is no way to control this.
What you would generally do is fix it by either connecting the islands using vias and manual traces or manually rerouting portions of the design so that the islands get resolved.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
m_eckhard
in reply to: jorge_garcia2
Hi @jorge.garcia,
thank you very much for your quick reply and clarification!
Kind regards
Jorge,
I wonder if there is any work being done in the Autorouter code to make it possible to automatically reconnect polygon islands. We see the polygons getting chewed up a lot, and it ends up generating 10, 20 and even 30+ airwires sometimes. Certainly, it can calculate the airwires, so it should be able to see ways to connect, since that is what the Autorouter is all about, right?
