Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Feature request: more options in package generator
3 REPLIES 3
robert.martinUKYP4
130 Views, 3 Replies
The package generator is a godsend for the times I have to use it and I am generating a standard chip size and footprint. However, there are times when a specific stop layer has been defined on the datasheet and I have had to go back and manually edit the dimensions of tstop and tcream.
Would it be possible to implement a basic feature to adjust the clearance of the tstop and probably the tcream layer whilst making a package. When working with a 144 pin package and the clearance of the tstop layer is 0.07mm instead of 0.1mm, that would be a godsend.
Labels (1)
3 REPLIES 3
Hi @robert.martinUKYP4 ,
I hope you're doing well. Thank you for the suggestion, I'll pass it along to the team.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Hi @robert.martinUKYP4 yes there are ongoing frequent updates to the Package Generator. This is very helpful to hear form you. Some of the recent updates make it easier to customize a footprint in ways like this.
So just to be clear on this page you'd like to also see an override for solder and paste mask openings, right?:
Ben Jordan
Senior Product Manager, Fusion 360 Electronics
LinkedIn | YouTube | Personal Blog | Fusion 360 Electronics Series
Hi Ben,
An override for solder paste and mask would be ideal
