Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
[feature enhancement] change document desynchronization warnings
0 REPLIES 0
Message 1 of 1
djon_3V3
94 Views, 0 Replies
Hi there.
If i open an electronics schematics without opening the project itself, i get a banner warning that documents might not sync if modified.
I think there are multiple problems with how this is done, but it is present right when opening the document. Not sure it is okay to remind me immediately that i might be doing something wrong even if i know it, and even if document is still very ok until it gets modified.
Would be like someone reminding me all the time that stairs are dangerous, even if i just pass by. Yeah, i know, you said it million times, i got it and i am not going to use them. Thanks but get a bit more conscious of context.
then
- this message ought to only appear IF we make a modification AND propose to open the project on a click so the situation is safe.
AND/OR
- we should also get a fair warning if we try to save a modified unsynched document
OR
- documents that can trigger an unwanted amount of chaos should not be editable until you figure out a way to make that safe in every cases.
Have a great day.
Labels (1)
0 REPLIES 0
