Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
[FEAT. REQUEST] Edit thermal relief for specific pads
2 REPLIES 2
marcocipriani01
141 Views, 2 Replies
I'm working on a big PCB which has both large through-hole connectors and small 0402 components. I need different widths for the thermal reliefs of each components. Is it possible to add, in a future release of Fusion 360, the ability to select a single pad of a component and enable a "thermal relief override", which changes the width and n. of spokes of the thermal relief?
At the moment, I created a lot of polygons, each with different thermal relief settings, but this operation is really annoying and time-consuming...
Kind regards,
Marco Cipriani
2 REPLIES 2
Hey Marco,
Thanks for the suggestion, I've made a feature request for it.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Great, thank you. I don't know how difficult of a feature it is, but if you could implement this in the next release it would be absolutely amazing.
Another pad-related feature to add would be teardrops... The teardrop ULP script  is a bit annoying to use, as it adds teardrops everywhere using little pieces of tracks, so moving the track connected to the pad messes everything up. Something like a checkbox on a "Pad properties" menu would be perfect... together with the thermal relief override!
Kind regards,
Marco Cipriani
