f/b antotion not active bug
when i added a new part seen below  in PCB the part dint show up i'm after placing components and this specific part was the only one which dint show up (note i did have a different audio jack previously i just removed it and replaced it with this one )  i have tried adding the component on the board via the a components command in PCB but problem there is that dint have  the pins are connected in the schematic vs the board  can you please  let me know what i can do to fix it  so i can get to routeing the board i'm doing
Replies (0)
