Exporting Electronics Library Issue
travis.cullen
travis.cullen
I'm attempting to export my electronics library used with my board but am encountering a strange issue. When i click export library, select the libraries that i wish to export, and then okay, i receive a popup that is typically used for uploading files. I would expect that the "select save location" pop up should be here in stead so i can choose where to save the exported library on my local computer.
jorge_garcia
Hi @travis.cullen,
I hope you're doing well. This is as designed, when you export libraries in Fusion 360 from a design they go into Fusion Team which is where your libraries should live.
What you can do is then open the library in Fusion Team and export to an EAGLE library if you wish.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
