Announcements
Export traces layout
lovro_kocevarribic
lovro_kocevarribic
I have an educational license for Fusion. I design my PCBs with Fusion and I would like to manufacture them at home using acid etching. To do that, I need only the copper trace layout without components on it because I transfer toner to the PCB to protect the traces. If I go to outputs and click print, it shows copper traces and component layout. Is there any way to export them in real size?
I manufacture them at home because it takes very long to ship them to my country, and it is cheaper to make them at home because I make a maximum of 2 pieces.
Thank you for answers.
m.neujahr_at_moe
Hello @lovro_kocevarribic ,
you can print out sperate layers if you first only turn on those layers you want to manufacture:
  • Normaly for top:
    • Top, dimension, vias and pads
  • Normaly for bottom:
    • Bottom, dimension vias and pads
You can now print your design.
If you want to "mirror" your printout, you can set it in the print dialog:
Eagle 9.6.2 / Fusion 360
Working with Eagle since Version 3.x
