EXPORT image doesn't seem to respect the board dimensions
robduarte
robduarte
When I use the image export function (by typing EXPORT via the CLI), the image that it produces does not match the dimensions (specifically, the ratio of width to height) of the board. In the screenshot below, you can see that the dimensions do not seem to correspond to the aspect ratio of the board. I've also attached the image produced, where you can see the issue as well. Choosing "Window" under the "Area" dropdown does not help.
Rob Duarte
Associate Professor in Art, Florida State University
Co-Director FSU Facility for Arts Research
http://art.fsu.edu/rob-duarte/
Twitter | YouTube
yqliu
@robduarte , can you turn on all layers and check if there is any object outside of the board outline?
robduarte
Yes, that was the issue. There was some text on the tValues layer that extended beyond the board outline.
Rob Duarte
Twitter | YouTube
