Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
EXPORT image doesn't seem to respect the board dimensions
2 REPLIES 2
robduarte
215 Views, 2 Replies
When I use the image export function (by typing EXPORT via the CLI), the image that it produces does not match the dimensions (specifically, the ratio of width to height) of the board. In the screenshot below, you can see that the dimensions do not seem to correspond to the aspect ratio of the board. I've also attached the image produced, where you can see the issue as well. Choosing "Window" under the "Area" dropdown does not help.
Rob Duarte
Associate Professor in Art, Florida State University
Co-Director FSU Facility for Arts Research
http://art.fsu.edu/rob-duarte/
Twitter | YouTube
Labels (3)
2 REPLIES 2
yqliu
in reply to: robduarte
@robduarte , can you turn on all layers and check if there is any object outside of the board outline?
robduarte
in reply to: yqliu
Yes, that was the issue. There was some text on the tValues layer that extended beyond the board outline.
Rob Duarte
Twitter | YouTube
Technology Administrators
