Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Export DWG/PDF to tNames/bNames, Silkscreen and Pads
1 REPLY 1
Kristey
78 Views, 1 Reply
Any ULP to create a file with a DWG or a PDF with some layer informations?
I design the schematic and the board and we have another team to build the PCB+components.
They always ask for a document so that can print and identify the components and polarities.
What I do now is choose the layers I want and print manually.
But isn't there a way to ask this question with any UPL?
Best Regards
1 REPLY 1
jorge_garcia2
in reply to: Kristey
Hi @Kristey ,
I hope you're doing well. The procedure you've been following is basically the best way to do it. One thing you can do to speed up the workflow is create a layer set that only contains those layers. That way you can quickly switch to the assembly drawing view.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
