Error while saving the PCB board for a Schematic. electron failed to generate small thumbnail.
TS02225217
TS02225217
i am having problem with saving the PCB file for a schematic. Whenever i try to save the file this error shows up.
Error: The board filefab_re has errors and cannot be saved.<br/>
Warning: Electron failed to generate a small thumbnail.
jorge_garcia
Hi @TS02225217 ,
I hope you're doing well. Go ahead and do the export and close, then send the files over to support. That particular error indicates that the board got corrupted. Can you recall what you were doing before this happened?
That can help us narrow down what could have caused the corruption. It's likely that we can recover the file. If you don't want to deal with this process then you can also fall back to a previous version of your design that didn't have the issue.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
