Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Error message in 3D PCB tab and misplaced components, possible bug in latest ?
3 REPLIES 3
xpuipc
198 Views, 3 Replies
since the last update to 2.0.8335 i get this warning:
...every time after
1. pushing 2D PCB to 3D pcb...in the timeline you can then see this:
The pcb looks fine here but when i
2. use this pcb in my enclosure (the board is referenced there)
most of the components are not placed correctly (two are correct):
with the previous version this workflow worked fine..
Anything i can do here ?
Thank you
Torsten
3 REPLIES 3
panpan_fan
in reply to: xpuipc
Hi @xpuipc
I hope you are doing well.
I see your description of the Issue and I think it may be a bug  (package components aren't included in the joint group)that has been fixed in the Fusion V2.0.8335. But the 2d/3d PCB which you have created in old Fusion version may still have the issue.  Can you try to add or delete a part in the schematic and Switch to 2d PCB, View 3D PCB to check if it will solved the problem?
Best Regards
Panpan Fan
xpuipc
in reply to: panpan_fan
@panpan_fan 😀...did it...now works...😀
Thank you for your help
Torsten
panpan_fan
in reply to: xpuipc
Hi @xpuipc
I am glad it works. Thanks for posting the issue in the Fusion Forum. If you have any issues when using Fusion 360, please let us know, thanks!
Best Regards
Panpan Fan
