- Mute
- Permalink
- Report
since the last update to 2.0.8335 i get this warning:
...every time after
1. pushing 2D PCB to 3D pcb...in the timeline you can then see this:
The pcb looks fine here but when i
2. use this pcb in my enclosure (the board is referenced there)
most of the components are not placed correctly (two are correct):
with the previous version this workflow worked fine..
Anything i can do here ?
Thank you
Torsten
