Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Error: Invalid cusp height for the given tool.
4 REPLIES 4
VE_Mohamed
179 Views, 4 Replies
I am trying to engrave a PCB. I am using a V Engrave/Chamfer self-defined bit, and 3D adaptive clearing.
On trying to generate toolpath, I keep getting:
I saw previous posts on this error, but all related to Ball end bits. Why I am getting this error with the V bit?
4 REPLIES 4
seth.madore
in reply to: VE_Mohamed
Would you be able to share your Fusion file here or privately?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply. To share the file privately, it's the same process, but email it to me: seth DOT madore AT autodesk DOT com
Seth Madore
VE_Mohamed
Please find attached.
seth.madore
So here's the deal;
The tool type is really not suitable for the toolpath calculation kernel that Adaptive uses, it requires a non-zero tip tool, and even then, would result in a toolpath not really suitable for this application.
I took your model and I've applied a few toolpaths to it. There are two setups, I'll explain what I did.
1) In the first setup, I used a 2D Pocket toolpath and selected all the chains appropriately. I did have to define your tool with a small flat on the tip (which it's most likely going to have anyways) and this was my result:
In my second setup, I thought I could do something clever and use 2D Pocket with a Silhouette or Pocket Detection, but that wasn't possible with the model "as-is". It kept on trying to machine the small holes, so I created a Manufacturing Model and then just plugged the thru holes. I was then able to use Silhouette to quickly make a toolpath, and it's pretty much the same as the image above. I think there's a case here for "ignore holes" when doing silhouette detection (I'll make a ticket this weekend)
I then tried 3D Pocket Clearing, but try as I might, I was not able to get a satisfactory toolpath, as it was missing several features:
File is attached for your review
Seth Madore
VE_Mohamed
Hi Seth,
Many thanks.
Let me share a couple of general comments first:
1. As Autodesk is not posting any official videos of its own on how to manufacture a PCB, all these videos out there are really misleading. I can even claim that most of them get what you called above a "non-satisfactory toolpath" but they just didn't highlight
2. My PCB is not much different from others, what works for me should work for others I guess. If 2D pocket clearing is the most suitable, then may be as a future enhancement, no need to keep such a generic manufacturing interface and just keep those strategies that can support PCB manufacturing.
Thanks again
