Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Enclosure don't update the size when we change the size of the PCB driven
1 REPLY 1
autodesk8LRWT
42 Views, 1 Reply
hello everyone.
I made the PCB design, then made the inclosure from the driven, but I needed to make changes on the PCB and the enclosure wasn't updated, lost all projections of the PCB outline.
what am I doing wrong.
Best regards
1 REPLY 1
Hello @autodesk8LRWT,
I hope you're doing well. Could you provide some images?
If the outline of the board has changed considerably (extra vertices or line segments) then the projections may break. Having more info can help us get to the bottom of this.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
