Empty window when opening a library
dieter.menne
dieter.menne
After each fresh start of the program, wenn I double-click on an Electronics Library in my project - created in Fusion 360 only, without EAGLE - the Windows open, but there are no items in it.
When I close the Window and re-open it, everything is fine. This looks like a minor bug, but it can be irritating. So just retrying helps.
RichardHammerl
Hi Dieter,
doing some clean-up here in the Forum I found your question from February 2020 unanswered...
Meanwhile this problem has been fixed with one of the recent releases of Fusion. The library editor is working correctly now.
Best regards,
Richard Hammerl
dieter.menne
Yep, closing! Ok, there is no Close button, and I accidently accepted my own answer. Cudos to Autodesk
