Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
ElectronicsPackageGenerator error when starting Fusion 360
8 REPLIES 8
Message 1 of 9
oklimberg
423 Views, 8 Replies
When starting Fusion 360, I get the error from the attached screenshot.
I Already tried to uninstall and install the product from scratch, but the error remains.
Running Fusion 360 on a 2019 MacBook Pro with macOS Catalina (10.15.7)
Labels (1)
8 REPLIES 8
Message 2 of 9
wangjiong30
in reply to: oklimberg
thanks for reporting this problem. This is maybe a issue of package generator to support case sensitive OS.
we made a fix in the upcoming update of fusion.  meanwhile, you can try to manully fix it.
in the following path
your machine pathyour machine path
please rename the folder "Resources" to "resources" and give a try.
hope this works for you.
Message 3 of 9
oklimberg
in reply to: wangjiong30
Thank you for this workaround until the fix is released.
Yes I do use a case sensitive file system which is not the usual configuration on a mac. Sorry I forgot to mention this in my initial post.
Message 4 of 9
Hi @oklimberg ,
Hope all is well.
We have a good news to share with you that we have put a fix in today's latest update of Fusion 360 (version 2.0.9439).
Could you please have a double check to see whether it works for you or not?
Thank you very much for your reporting.
Please feel free to let us know if need our further assistant.
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
Message 5 of 9
AlinaPeng
Hi @oklimberg,
Hope you are doing well!
Please let us know if the fixing works for you. Thanks very much for contacting us!
Alina
Alina Peng
SQA Engineer
Message 6 of 9
oklimberg
in reply to: AlinaPeng
I am unable to test your fix, because the lastest version crashes upon Start. I could only submit a report (which I did).
Message 7 of 9
Phil.E
Please check your private messages.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 8 of 9
oklimberg
With the help of Phil, I was able to get Fusion 360 running again, without any error on startup.
So I would say the initial issue is solved in the latest version.
Message 9 of 9
Phil.E
Thanks @oklimberg
For anyone else who might face this before we can issue an update:
I've contacted everyone who sent in a crash report for this error, as of this hour. If you get a crash error dialog, please send it in.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
