Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Electrical Schematic PDF Print Text off by 3 Characters
2 REPLIES 2
o_oweson
199 Views, 2 Replies
The PDF print output of an electrical schematic changes all of the text (letters and numbers) inputs and shifts them by 3 characters.
pdf outputpdf outputscreenshot of projectscreenshot of project
Labels (2)
2 REPLIES 2
jorge_garcia2
in reply to: o_oweson
Hi @o_oweson ,
What device did you use to export the PDF. The oficially supported driver is called Print to File(PDF) if you use anything else you might not get good output.
This is the first time I've seen something like this so the more info you can provide , the sooner we can get to the bottom of this.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
o_oweson
in reply to: jorge_garcia2
@jorge_garcia2 I was using Adobe PDF, which my setup had defaulted to, changing the setting to Print to File did solve the issue, and gave me a correct output, thank you!
Nonetheless a very bizarre bug.
