Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
EAGLE, Copy and Paste does not work between schematic sheets
4 REPLIES 4
matthew.eldridge
610 Views, 4 Replies
I've noticed that copy and paste does not work between schematic sheets.
Repro:
1. with a schematic on sheet 1, select everything and Ctrl-C
2. on sheet 2, currently blank, hit Ctrl-V to paste
Expected:
- copy of schematic from sheet 1
Actual:
- nothing shows up
3. go to the edit "menu" in the toolbar and select "Paste" from the dropdown
Expected:
- nothing shows up (I already used Ctrl-V to paste the copy, and nothing happened)
Actual:
- the copy from step (1) magically shows up
Possibly relevant: I was copying and pasting between modules, so not top-level sheets
4 REPLIES 4
Hi @matthew.eldridge
I hope you are doing well!
From your post, I guess you use the hot key to do copy and paste with two sch/pcb files open in Mac.
If you confirm that, then it is a known issue that we are working on.
As a workaround, do you mind relaunching Fusion 360 and only opening one schematic file to have a try?
And also you can use the copy and paste commands in the menu bar to have a try.
If the workaround still can't work, please let us know. Thanks!
Panpan Fan
Jus to chime in...
I'm on a Mac and this works fine.
Select a block of components
Command-C to copy
View other sheet
Command-V to paste
I should have said, I'm on a Windows 10 box. My repro for the problem is based on using the hot keys, Ctrl-C to copy, Ctrl-V to paste. Interestingly the Ctrl-C seems to work, while the Ctrl-V does not. I can paste successfully using the toolbar button to paste.
This isn't a huge deal, just a minor annoyance so I thought I'd point it out.
Thanks for your comment!
I will give the information to our develop team to have a look.
Panpan Fan
