Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Drop-in / mid mount component foot print
0 REPLIES 0
Message 1 of 1
11330015
277 Views, 0 Replies
Hello every one
I am tring to make a footprint for a usb connector which is drop-in at the level of the board also known as mid-mount usb (see image attached below) so there must be a cutout in the PCB. I have tried to draw the cutout in the Milling layer and it worked but when i place the on the edge off the PCB but the cutout will automatically disappear or level small edge, i wonder how i can solve this problem, or may be remove the edge clearance but I also don't know how, does the drawing in milling layer must be closed or for example open square is enough.
Thank you for your time
0 REPLIES 0
