Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Drill Legend ULP does not work?
1 REPLY 1
eric_engineer
130 Views, 1 Reply
I have a simple board. I tried to run the Drill Legend ULP command.  It starts throwing errors about layer 51 right away.  Then the first few times it lept from my pcb into a library I had open and created the drill drawing there.  With a bunch of popup errors.
I closed the library and tried to run the ULP again, same types of errors only this time it created nothing.  Does drill drawing just not work?
Also is there a similar tool for a stackup drawing or do I have to do it manually?
Thank you.
1 REPLY 1
I was able to get this to work (by magic? luck?  Not sure).
