Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
DRC jumps to wrong position
3 REPLIES 3
jimUR4RG
128 Views, 3 Replies
When I click on a DRC error, the screen is supposed to jump to the position of the error. However, it jumps to the wrong position, quite far besides the board. This makes board design quite cumbersome as I now have to zoom out and manually zoom to each DRC error.
Does anyone else have this problem?
Labels (2)
3 REPLIES 3
engineeringNCMXB
in reply to: jimUR4RG
I have not seen that problem.
Try turning on ALL layers before you run DRC. there may be something out there that is on a layer that is turned off.
Carlos Acosta
Factory400 - YouTube|Instagram
jorge_garcia2
Hi @jimUR4RG ,
By any chance do you have the board flipped? If the board is flipped then the DRC error marks will point to the wrong location.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
jimUR4RG
in reply to: jorge_garcia2
Thanks Jorge, this solved my problem.
