DRC error: OUTPUT and SUPPLY pins mixed
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I read on the Autodesk Eagle forum that this could be ignored, as it should present itself as simply a warning. However, it's an error in Fusion.
So, what is the recommended way of hooking voltage regulators up to the supply pins of opamps in Fusion Electronics? That's what I'm trying to do here.
Initially, I figured I could just name the net from the regulator output pin +11V, and do the same with the name of the net going into the opamp supply. Now they're the same net. That didn't work all too well.
There is a library called supply1, so I tried connecting the component V+ to the net, and that's when I got the error.
How am I supposed to do this? There is a probably a simple solution.
